BBC iPlayer will not fire up on XR-55A80J
smokestack1964
Member
IPlayer no longer opens when selected. All other apps open ok. This app also can’t be uninstalled and re-installed. Any help appreciated?
1 ACCEPTED SOLUTION
Elodin
Moderator
Hey, try uninstalling the updates on the live TV and catchup app by going to Home - Settings - Apps - live TV and catchup and select uninstall updates. I hope this helps
15 REPLIES 15
LightFoot
Specialist
Hi @smokestack1964   I would start with a soft reboot. Hold down the remote power button until you see Restart. There is an outside chance that you may have to do a factory reset.
smokestack1964
Member
Thanks, I’ve tried that and it didn’t work. I’m not factory resetting the TV as can’t be arsed to go through all the set up again.
LightFoot
Specialist
smokestack1964
Member
Yes it’s up to date, SonyUser.
Elodin
Moderator
Hey, you can try and clear cached data on your TV by following the steps here: Home - Settings - System - Storage - Internal Shared Storage - Cached data - Clear. I hope this helps.
smokestack1964
Member
Thanks Elodin. Unfortunately that hasn’t worked. Appreciate the input.
clonebrother
I'm having the same problem on the XR-55A90J - None of the British TV apps work (BBC iPlayer, Channel 4, iTV).  You tap on the app and nothing happens.  I have the latest software and have rebooted the TV, no change.  Other apps like Netflix or Disney+ are fine.
Elodin
Moderator
smokestack1964
Member
Thanks Elodin! That’s fixed it for me.
It seems strange that that particular app update caused those problems.
