Hello.
During CES I heard a news that Sony will bring Android 6 (Marshmallow) to the 2015 TV lineup.
General News about Marshmallow on Android TV's
These news are from January.
Had anyone heard something new about this?
Hi i also would like a link if there is one
thank yoo
I did an over the air update so I don't have any usb save. I don't think the marshmallow update is worth any great excitement or anticipation. The interface is a bit quicker and that's the only difference really.
But I am sure the loading screen must be completely different
Just my 2 cents... I updated my KDL-55W807C with a USB on the day after it's release and have had no problems at all. It felt a little bit snappier, but I also did a factory reset after the update, so that might be the reason.
It has solved the lip sync issue with Chromecast and Youtube, 95% of the times, and that was one of our biggest issues with the TV, so that's great. I don't know if the EPG problems has been solved, because we're now using our TV providers set top box so, but I do hope it's solved because it was not a good experience.
The TV does crash and reboot itself occasionally but not very often.
I upgraded my KD-55X8509C and have had constant issues with crashing and slow performance ever since. HDMI ARC has been even worse than before also.
Hoping an imminent release will solve these as at times the TV is so slow you can barely use it.
Fingers crossed for this imminent release.
Did you try any apk explorer from google play ?
Srry if my english not to great!
Sony Denmark support page says it's the release of the new update.
