2015 Bravia Android TV Issues
NickCo1979
Участник
I thought I'd create a generic thread to cover off the issues being encountered on the 2015 Bravia Android TVs. I've listed my issues below with fixes / workarounds and responses from support. All comments and solutions welcome!
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
2) HDD Recording doesn't work - error message states a system update is required but none is available when checking. Hopefully this will be fixed soon by a firmware update.
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
4) Sound lag and performance issues after the TV (KD-49X8305C) has been on standby for a while - manifested for me as stuttering and sound / picture sync issues in all apps (youtube, amazon instant video etc) and HDMI sources (PS4, seperate YouView box etc). Hopefully this will be fixed in a firmware update, at the moment workarounds involve either changing channels to get the sync to work or in my case having to turn the TV off and then on again at the socket.
As stated previously, all comments welcome. Personally I'm willing to give Sony a couple of weeks to fix this, but if it's not done soon I'll be sending my new TV back for a refund as it's not really fit for purpose.
6 373 ОТВЕТ 6 373
Brigante01
Участник
Not sure which model you have in mind having 100ms response time? I'm using the 43X830C as my main computer monitor and at 4K 4:4:4 I've never had a problem with input lag on any type of game.
It might not be the monitor for you if you're a competitive FPS gamer but for anyone else it's perfectly fine.
Shodney
Участник
I've got the 850C, which is just short of 100ms (see measurements at
http://uk.rtings.com/tv/reviews/by-usage/hdr-gaming/best ).
The 830 doesn't have HDR, which seems to be what pushes it up.
Brigante01
Участник
That sounds like a probable explanation! I went for the 830 because of the low input lag.
If they could just sort out the 4K judder then it be pretty much perfect for me.
Anonymous
Неприменимо
Dear all
This thread is now CLOSED !
If you would like to continue a discussion, please do so in the following thread:
https://community.sony.co.uk/t5/the-lounge-room/android-tv-discussion-thread/m-p/2233333
If you have issues or problems, please create a new thread on the Android TV board:
https://community.sony.co.uk/t5/android-tv/bd-p/Android_TV
Cheers
Note: Due to a lithium forum restriction, this massive thread cannot be moved at the moment.  A support ticket has been raised and when resolved, it will be moved to the Android TV board.
