- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Update to A7M3 Firmware from 3.10 to 4.0
Hi, Has anyone tried to update their A7M3 to the latest Firmware version? I have tried to follow the on line user guide for the update and it always fails. The guide suggests turning the camera off and removing the battery and then re-launching the Updater App. After the 4th attempt with different USB cables I have stopped trying until I get some feedback from Sony or other users as to their experience? Has anyone tried this yet?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Have you tried using a different PC/laptop? I've seen others with the same issue getting it fixed just like that, and it wasn't even a different operating system or version.
Hope this helps!
- JD
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hope this helps!
- JD
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
to no avail.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
This is a bit thin, but have you tried installing PlayMemories Home, connecting your camera, then trying the update?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
A wild suggestion.
Do a factory reset and try again.
It works with stubborn smartphones, so why not with stubborn cameras.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi luciano.o, did you check the required operating system? Some mac version won't work simply. If yes, the next step after Strampke's suggestion is to send the camera for an inspection.
- « Previous
- 1
- 2
- Next »
