SONY NEX 5R
akymovies
SONY NEX 5R
Hi Guys,
I have a sony nex 5R camera with 18-55mm lens. I was wondering if I can shoot short movies (30fps) with this camera? or do you have any other suggestions for me? Like should I get a different camera or lens?
3 REPLIES 3
Sean_Mc
Moderator
Hi there,
I've had a look through the manual to try find more details on this, but unfortunately it doesn't say if it's possible to shoot in 30fps.  There is only info on page 29 of the manual on 'Recording movies'. You can find more details here.
Perhaps another community member may be able to answer your query.
Cheers,
Sean Mc
akymovies
Thank you for looking into it. Will go through the link that you have referred to below.
darkframe
Hi @akymovies,
well, according to this PDF (which reads NEX-5T at the top) you need to set "MENU -> [Image Size] -> [File Format]" to MP4 and thereafter movies will be recorded at "about 30 frames/second".
Cheers
darkframe
Wo kämen wir hin, wenn jeder sagte, wo kämen wir hin und keiner ginge, um zu sehen, wohin wir kämen, wenn wir gingen... (© by Kurt Marti)
