Hi All
i just bought my sony a7 markiii and wanted to know if i have to use the UHSii card on slot one or can i just use any card?
https://helpguide.sony.net/ilc/1720/v1/en/contents/TP0001667693.html
[Slot]
SLOT 1
Slot for SD cards (UHS-I and UHS-II compatible)
SLOT 2
Multi-slot for Memory Stick PRO Duo and SD cards (UHS-I compatible) Supports operations between two memory cards.
Manolo
Thank you. But when I insert UHS one it is giving me an error message and asking me insert card to slot one
Have you an SD Card also into Slot I or is Empty?
Manolo
