Resetting file number to 0001 on ARiii
walt_g
I normally shoot with 'File Number' at Series so the file numbers increase across cards. At the beginning of the year I like to reset the file number back to 0001 to restart the series over again. I cannot find a way of doing this. Even if I change to 'Reset' the numbers continue to mount.
1 ACCEPTED SOLUTION
Mick_D
Moderator
Hi @walt_g
Have you tried the Reset on a newly-formatted card? I'm pretty sure that will create a new folder, which is often the only way to start again from 0001.
Cheers
Mick
2 REPLIES 2
walt_g
Sorry, I mean the A7iii.
Mick_D
Moderator
Hi @walt_g
Cheers
Mick
