hello hope someone has the answer here,
i have banding in some footage. At first i though it was just due to the LED lights the dj was using but since none of the normal fixes have worked im a little worried its the camera.
I can only see it in some of the night footage the rest looks fine. can anyone help?
Hi there,
Have you updated to the latest firmware?
Best wishes,
M
Hi AshleighA7s,
Welcome to our community!
You mentioned that you can only see the in some of the night footage but the rest looks fine. This suggests it's not a fault with the camera but could be related to using certain shooting settings in certain conditions shooting conditions. were you using the silent shooting mode or the E-front curtain mode when taking this one?
Regards,
Batee5
