FE 24-105mm F4 G OSS with A7 ll compatibility
TProcter
I’m thinking about buying this lens but when I have checked the compatibility info on Sony’s site, it shows the following info.....
  • The [Lens Comp.: Distortion] setting will be set to "Auto".
Does anyone use this lens with the A7ll? I’d appreciate your views on it and would love to see some pics please.
Many thanks
Tracy
3 REPLIES 3
Pascale_F
Moderator
Hi Tracy,
Welcome to the community.
I'll look into this for you and see if I can find out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Tprocter,
I am not sure about this restriction, but I don't think it should affect your shooting experience in any way. I've found some sample photos taken by this lens on the Sony Photo Gallery.
I recommend that you've a look here: https://www.sony.net/Products/di_photo-gallery/lens/SEL24105G/?select=lens&mount=E-mount
Cheers,
The_Black_Rose
GeneralDogsbody
I think this is something to do with a function in the camera which corrects lens aberations (all lense have aberations) . The 24 - 105 is an excellent 'walk around' lens. Buy the lens with equanimity and enjoy sharp images.
