COMPATIBLE RECORDING MEDIA
pan2000z
I have a Sony ILCE6000 camera and I have bought a Sony MSHX32B 32GB Memory Stick Pro-HG Duo HX (without Adapter)
Is there an adapter so I can fit this memory stick into the ILCE6000?
It is clearly stated on the specification page of the ILCE6000 > COMPATIBLE RECORDING MEDIA as follows,
'Memory Stick PRO Duo”“‘, Memory Stick PRO—HG Duo“, Memory Stick XC-HG Duo, —— SD, SDHC, SDXC memory cards'
1 ACCEPTED SOLUTION
Pumpkin_Duke
Member
You don't need an adaptor. It's a combi slot for SD and MS Cards.
Cheers
PD
2 REPLIES 2
Pumpkin_Duke
Member
Cheers
PD
pan2000z
Thank you - I had so many conflicting answers.
Now will it work with XAVC S?
Thank you again!
Alan Miller
Edited - Personal info removed
