Hi my finder/monitor has stopped switching automatically. the view finder is clean. The finder/monitor switch is on Auto. Only had the A9 a couple of months and disapponted with this.
Hi Sue,
Could you please try the troubleshooting tips here to see if that helps reset the finder/monitor.
Let us know if this helps.
Best wishes,
Ed
I've seen this caused by dust or water on the eye sensor. Remove the rubber eyecup and clean and all should be well.
