Alpha 7 mk iii. Problem updating firmware for v1.01 on MacOS 10.13.6
hugriff83
 I have downloaded the new firmware and started the system updater. However after checking that the USB connection is set to Mass Storage (it is), I get the following screen:Screen Shot 2018-07-22 at 17.52.23.png
And the update can go no further.
What is the solution to this?
Hugh
1 ACCEPTED SOLUTION
batee5
Specialist
Hi hugriff83,
Welcome to our community!
On the update page on Sony's website, it mentions under the "System Requirements" section: "For macOS 10.13, please ensure the "DriverLoader_1013" has been installed before update your software.". Could you confirm that you have installed this software on your Mac before trying to update your camera?
Regards,
Batee5
5 REPLIES 5
Sean_Mc
Moderator
Hi Hugh,
I've checked this for you.  It would seem, if your system software version is Ver.1.01, then the update is not required.
Best wishes,
Sean Mc
hugriff83
Thank you for this. However my problems are in updating TO v.1.01 FROM version 1.00.
Also I need to know why I get the error messages ai showed before ...
Many thanks,
Hugh
Hugh Griffiths LRPS
M: +44 7958 524 787
www.creativelight.org.uk
Sent from my iPad Pro
batee5
Specialist
Hi hugriff83,
Regards,
Batee5
hugriff83
Brilliant ... all fine and dandy now. Thank you!
hugh
batee5
Specialist
Hi hugriff83,
I'm glad to know it's been sorted. :slight_smile:
Regards,
Batee5
