WEBCORD
a9ii fn menu set
My wife just got an A9ii and having problem setting function menu. She wants to add "drive mode " to a Fn menu slot. However the drive mode slot is greyed out and not available. If this is never available why is it there. I have an A7ii and can do this on my camera so I thought maybe it is because the A9ii has a dedicated wheel for drive mode and also for exp comp .
However the A7iii has dial for exp.comp and can have a slot in the Fn menu.
After reading the last question here I would like to know if this is indeed a software problem, sorry "glitch", or not.Also how many other people are experiencing this? could it be a "bad batch" of A9ii's?
Basically, can you assign drive mode to the Fn menu on a9ii or not?
Tags (1)
1 ACCEPTED SOLUTION
WEBCORD
Thanks for the reply, as you say you don't have an A9ii and they are different to the A7ii etc. The problem with our A9ii seems to be that it needs the firmware updated to solve a "glitch" in registering items to the Fn menu.
As well as this, on the A9ii , because it has a dedicated mode dial, no means to add to fn menu.
All sorted but thanks for takin the time to help.
Cheers
Steve
5 REPLIES 5
darkframe
Hi @WEBCORD,
maybe I'm asking a dumb question but isn't the option to change the drive mode assigned to the Fn menu anyhow? I'm asking as I don't have an A9 but found this in the online help.
Sorry if I'm totally wrong.
Cheers
darkframe
Wo kämen wir hin, wenn jeder sagte, wo kämen wir hin und keiner ginge, um zu sehen, wohin wir kämen, wenn wir gingen... (© by Kurt Marti)
WEBCORD
Cheers
Steve
Joe_Dohn
Specialist
So the "glitch" was solved by the latest software update for you?
WEBCORD
yes it did.
Joe_Dohn
Specialist
That's great to hear and thank you for taking the time to confirm! ^^
