Hello my a7iii does not connect to my tv uhd Samsung series 7 by WiFi .... the camera detects it but it stays there trying and nothing.
Someone knows?
Thanks
...... en español .....
Hola mi a7iii no se conecta con mi tv uhd Samsung serie 7 por WiFi.... la cámara lo detecta pero se queda ahi tratando y nada.
Alguien sabe?
Gracias
Hello @Rodin37,
I think the cameras WiFi capabilities do not allow photo playback via WiFi-direct (when connected to a TV), which might be the reason it is failing.
You can always use a HDMI-cable OR take out the SD-card and connect it directly to the TV via a USB-cardreader to play your photos/videos.
- Nic
