- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
A7C II - SDXC V90 warning message
January 2024.
SONY A7C II, fw 1.01
I have recently been getting the message 'To perform shooting with this setting, use a memory card higher than SDXC V90.' in video mode.
I get this with Sony Tough G-series cards and ProGrade V90 cards. Camera is set to record XAVC-intra frame, 1920x1080, 25P so not particularly high data rate.
The A7C II only has one card slot. My SDXC are the fastest cards currently available. The camera doesn't have a CFE type-A slot.
I can of course hit OK and carry on shooting as normal but this looks like a software bug? maybe worth letting the engineering team know?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
In my case all my SDXC V90 cards are 128GB so storage space isn't the cause of the error.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @0073540500008048 It sounds like you might be encountering a software bug with your Sony A7C II. Here are a few steps you can take:
- Ensure your camera's firmware is up to date. The latest version is 1.02, which addresses several issues: https://www.sony.com/electronics/support/e-mount-body-ilce-7-series/ilce-7cm2/software/00301105
- Double-check that your memory cards meet the required specifications. The Sony A7C II supports UHS-II SDXC V90 cards. If your cards are compatible and you're still experiencing issues, it might be worth trying a different brand or model to see if the problem persists.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
April 2025
I'm presuming that last message was auto-generated by a bot account? Literally everything 'recommended' in it has already been discussed and explained in great detail in this thread. If it was generated by a human: please read the earlier messages as it already has this information.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi all!
I just made an account just to share a solution that is working for me.
For context I´m using a Sony a7cii in the latest firmware with a Sony Tough V90 class G 32GB card (same model as OP with even less capacity).
What I did is just renamed and formatted the SD in MAC mini using ExFAT instead of FAT32 (which is the format applied when you format in camera).
I really hope this also works for you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @dcmandrel,
if that really should be the reason why OP got the error message, then the text of the error message should be changed. As it stands it gives no clue about the file format the SD card was formatted to.
- Nic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It sounds strange to me… My A7iv and A7C use exfat to format the flash cards on camera.
I’ll try to format on pc as fat and than reformat on camera to see what happens
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just checked: on my cameras when I format on camera the file system became ExFat also if it start with FAT.
In FAT it can work and store pics, but by formatting it became ExFat
- « Previous
- Next »
