A7 IV - does not charge
enchiladagigi
I just bought this camera (it arrived 2 days ago), and it does not charge. I charged it for a few hours, and then it worked. And then stopped working. I thought it was an issue to do with the SD card I added into the camera, but it actually just shows that the camera is not charged.
I have just put it back on charge and is showing the battery symbol with a line through. I have also just attached it do a different adaptor to see if that changes anything.
Has anyone had any similar issues with the A7 IV? Or do we think that there is an error in the manufacturing of the camera I have received. Any advice would be most useful.
1 REPLY 1
danardeng
Contributor
Are you using the usb-c connector?
Is the camera switched off?
Those are the main conditions to recharge.
