A6000. Problems with display screen going off and on. like lose connection.
Camera is in excellent condition never been knocked or damaged but display can be quite annoying.
ALSO when transfering photos to phone via wifi it is hard to keep connection.
edited[personal details removed]
@Brian-XTKD wrote:A6000. Problems with display screen going off and on. like lose connection.
This detail is really important: can you tell if the wifi stability is the same or is got worst in coincidence with LCD issue?
This is the meaning: if the wifi stability is the same than before the LCD start to has this issue, than 99% is a problem of internal wiring of LCD. The fixing can be cheap.
But if the wifi stability is got worst with LCD issue, it can be a bad signal that the main board have a problem. The fixing cost can be way more expensive.
Anyway, it's an hardware problem that only sony's operators can fix. You should contact them. https://services.sony.co.uk/supportmvc/en/BookService/Disclaimer?cat=Camera¶meter=OTHER
EVEN WHEN TAKING PHOTOS THE DISPLAY SCREEN STILL TURNS OFF.
This can't answer to my question
Hey @Brian-XTKD
Can you make sure that your camera is up to date: (Windows): https://www.sony.co.uk/electronics/support/e-mount-body-ilce-6000-series/ilce-6000/downloads/0001595...
And try the steps here: https://helpguide.sony.net/gbmig/45349331/v1/en/contents/TP0000508393.html?search=initialize
If the same issue remains after that, you will need to send the device for service.
