- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Xperia 5 V: USB charging will not work in my new VW Golf
- Car / head unit make & model: Volkswagen Golf GTE 2025, MIB4
- Phone make & model: Sony Xperia 5V (XQ-DE54)
- Android OS version: 15
- Android Auto app version: 13.9.651014-release
- Google Play services version: 25.10.36 (260400-739992411)
Now with this new Golf I cannot charge my phone anymore via cable, data connection will work ok.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Charging in works also with old Nokia 8.
Xperia 5V fast charging works with home charger Sony UHC-32, and from my PC usb-c power delivery ports - so there is not wrong in cables.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @tos-82, did you try a different cable with the Xperia on your car? Does it still not work? Can you try a different Android phone through the same charger of your Xperia through your car and check if it will work? Also, can you try the same cable on a different car through the Xperia 5V?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you for your help.
I have tested 3 different cables, one of them was sony cable from my old xperia 5 II.
Older android phones will work well, like Nokia 8, Samsung A35 and Xperia 5 II.
Iphone with USB-C will use fast charging on my car.
I tested charging Xperia 5V from vw dealer (Passat 2025, same infotainment system), Settings says not charging.
Im glad that wireless charging is fast enough, but my phone get hot.
I tested also developer mode and other usb settings, no luck.
