Xperia 10 V fingerprint issues
profile.country.UA.title
arcade
Member
Hello.
Well, I tried a lot of things to fix this but it still happens no matter whet I try. After a few weeks of using fingerprint sensor to unlock phone fingerprint reading becomes slower and slower up to the point other apps and device start glitching hard:
 - There's a delay before reading a fingerprint and it's getting longer.
 - My bank app work fine for the first few weeks, but after it starts nagging my screen with "This app failed and has to be restarted". If I don't "restart" the app it continues to work without issues, but that message is coming again each 30 seconds, I can't even input bank card without being interrupted a few times.
 - Chat apps that are using fingerprint for extra security are failing to open. As I'm opening a phone by touching fingerprint, I'm going into the app, app wants to read fingerprint, and fingeprint reading just doesn't happen no matter what I try: take finger out for a few secs, hold it longer, just nothing. Minimizing app and going back to it solves the problem.
 - Sometimes when I'm opening my phone it kindda unlocks and I see my screen, but actually I can't do anything as over that screen I still see notification iunterface from locked screen, my device is still locked, it doesn't accept fingerprtint but may be unlocked by PIN if I get there. Sometimes even PIN doesn't work, I have to turn off device, wait for the sound of locking, then turn it off by pressing the button (without fingerprint), then when screen lights up I can use fingerprint to get in.
What I have tried:
1. Deleting and adding fingers kindda fix this thing for next few weeks.
2. Full factory reset doesn't change anything.
3. After firmware update phone is working fine again, but again just for a few weeks.
Is there any way to permanently fix this thing?
Thanks in advance!
12 REPLIES 12
EMS_MO72
Hey @Dako88
Did you contact Sony about this? To report it at least so they can tell if it will be fixed by a software update or something else?
arcade
Member
Well, yes, but I still got no response from them.
EMS_MO72
@arcade
Yes, their technical escalations take time usually.
Let us know the outcome though when they reply to you
