Warning triangel
profile.country.FI.title
Lumirotta
Warning triangel
Sorry i don't have great english
I have Sony Xperia 10 II but about every third time when I restart my phone (after the powerd by Android text) come warning triangel and on the triangel there is 2 tools.
Some apps didn't work and for example weather app, news apps and other light apps didn't work. It works about a few minutes and then black screen and app close.
can some help me and tell what I need to do?
3 REPLIES 3
Uliwooly
@Lumirotta
Are always the same apps that force close on you or different apps?
Lumirotta
Different apps
CosmicTomato
Specialist
The repair icon, it tells you that there are certain system repairs running at the time, when it came up on my device and contacted support, I was told to leave the phone on charge while it's turned on, cause if it's closed the repair will stop and continue once the device is on again. They also had stated the below:
Tests have been done with all grades of corruptness. In 95% of the startups, the repair will take less than a minute. In the worst case, the device requires several hours to scan and repair the files.
PS I was the worst case scenario cause it stayed like that for 2 days, hope it goes smoothly
