I have uk EE and Vodafone Sims in the 10 plus. The signal strength is always weak, and noticeably so compared to my old pixel 1, and even other HTC handsets I've used. It's so bad that I sometimes get no signal, and call drops when I had no issues in the past.
I've attached picture where I normally would have had full signal on both Sims.
@AndyCalling wrote:Can I check, are we all using the same app to measure strength? I'm new to Android so I'm guessing there's some app everyone uses? Please let me know which one. All I have to go on are the little bars at the top, which can't be used to compare between different models of phones or even different Android builds as the bars could mean anything. What's the go-to app everyone uses to compare signal strength with a standard measure?
@AndyCalling Regarding an app to compare signal strength. app AnTuTu
Wifi
Data
