Screen light up
LS80
Besucher
Screen light up
Can you make the screen light up when receiving a new notification. I find it annoying having to pick up the phone to see what has come through.
Thanks
1 ANTWORT 1
Jonas
Meister
Hi @LS80, welcome to our forum!
This feature is not available in the Xperia 10-series, however there are some applications that has this feature as default or as a setting that you can enable (those that I know about are Snapchat and Textra).
You can check in the Google Play store if there is any application available that will enable this function for all your applications when you receive a notification.
I hope that answers your question!
