No wifi
Nanshan
Visitor
No wifi
My brand new xperia 10 plus just stopped detecting wifi networks.
Any ideas
I have already tried diffwrent routers and factroy reset the device , also tried safe mode and so forth.
Xperia 10 plus does not even show any networks found.
5 REPLIES 5
Uliwooly
@Nanshan
Does it detect the carrier's network? have you repaired it with Xperia Companion?
Nanshan
Visitor
Yes it does connect to gsm networks and has full LTE
I will try the repair on pc and let you know if anything changes
pressefr
Contributor
Troubleshooting suggestions
1. Setting > Network > Internet setting > Download MMS
2. Reset Network setting via setting > system > reset option > reset network
3. DSN network quick find on router button
4. Toggle on/off airplane mode
5 turn off Auto Network Switch
I'd just return it and replace it.
Ram131
Visitor
Yes I have the same problem with wifi connection every day. This is not good...
AndyCalling
Visitor
Not good indeed. I guess by this you all mean that when scanning for wifi connections none are even listed? If so, then if a factory reset or Xperia Companion repair doesn't fix it I would guess the wifi radio or aerial inside the device is broken. Would sound like a replacement is needed.
