Bluetooth problem
PaMaWil
Visitor
Bluetooth problem
I purchased an Xperia 10 and have been unable to connect to any Bluetooth devices. The phone scans and identifies some and doesn't find others, and those that it does find fail to connect. I have carried out resets and updates where possible but with no success. Any ideas would be appreciated or I will be returning the phone for a refund. Thanks
3 REPLIES 3
ks2mulder
Visitor
I have the same problem, and also if i am connected and too many apps are open the connection stutters and its really annoying. I hope it van be fixed within a software update...
profile.country.NL.title
Strampke
You might try with cleaning up your settings.
Goto settings-> System -> reset options -> reset network settings
See if that helps.
Piter67
Visitor
Nic to nie dało nadal nie mogę połączyć się ze słuchawka bluetooth
Nothing else I could still connect to the bluetooth headset
gt
