xperia transfer mobile
Michi_Pupsi1
Visitor
xperia transfer mobile does not work on the xperia 1 .... what to do?
11 REPLIES 11
azzido
Enthusiast
@RuneJ wrote:
As mentioned before:
Backup old device via Google Backup/Drive and backup of photos via Google Photos will copy everything from contacts, sms, photos, files,etc  to downloaded applications/programs ( programs will be downloaded from Google Play Store and installed).
I went from an XZ2 to X1, everything was installed and setup on the X1.
It actually worked better that using Xperia Transfer in the pastSmiling_Face_with_Sunglasses
Tried this and it worked fine for everything except sms and call logs... On xz premium it says it is backuped, on X1 it says it is unable to find any backup...
azzido
Enthusiast
@Lightning09 wrote:
Hi Xperia Support,
Maybe you should revisit Xperia 10 plus bug on Software patch "Unresponsive Touchscreen" Aren't you suppose to support us too even if it's just a Mid Range phone?
They should revisit x10 plus bugs, but there is separate dedicated section for this device. This one is for x1.
