Xperia 1 IV 80 - 125mm camera lens
DavidSmith
Can Sony or someone help please.  I bought this new Xperia 1 IV to replace my older Xperia 5 as it is supposed to have a superior camera function.  I've tried the Basic, Auto and P settings but the telephoto lens options give very disappointing images.  They lack focus and definition.  They appear little better than taking a photo with the 24mm lens and electronically zooming in.  I'm using ISO 100 to 200 in bright light and with a fairly high shutter speed.  I have a Alpha 7R camera so am familiar with P settings.  Is there another setting I'm not getting correct or might there be a fault with the new phone camera?
Thanks
Dave.
5 REPLIES 5
IamNic
Hello @DavidSmith,
can you upload images you are not satisfied with to your next reply, so community members can check the EXIF data to find where the P mode messed up maybe?
- Nic
DavidSmith
This is an example of a jpg photo take in 4:3 format using the 125mm lens. ISO 100, F2.8 (not possible to alter), 1/2000 sec.
DavidSmith
And this example
Anonymous
Not applicable
Did you test it in safe mode? And you can also check this one if it helps.
profile.country.HK.title
dennck
Have you put any lens protection film/glass on the lens assembly?
Xperia 1 series lenses are VERY sensitive to lens protectors. It makes image fuzzy/blurry and introduce flares sometimes especially with the Xperia 1 IV 80-125 zoom lens.
