4K DCi page not found
profile.country.RO.title
Jacob_00
Hi, I'm trying to update DCI, but the page can no longer be found
5 REPLIES 5
For which Model?
Jacob_00
A7sIII
Adds support for DCI 4K (4096 x 2160) and 24.00p recording
ILCE-7SM3 System Software (Firmware) Update Ver. 3.00 (Windows)
https://www.sony.com/electronics/support/e-mount-body-ilce-7-series/ilce-7sm3/software/00257138
ILCE-7SM3 System Software (Firmware) Update Ver. 3.00 (Mac)
https://www.sony.com/electronics/support/e-mount-body-ilce-7-series/ilce-7sm3/software/00257159
Jacob_00
hello, I did the update as it should. the first time v2.5 and then v3.0, but I can't find DCI 4k in the device (PAL)24p . I understood that I had to enter in creators cloud to download from there, but the link is no longer valid.Does the region where I live matter? Romania. tnx for help
"Does the region where I live matter?"
In fact it could... (at the same Update Link you can read):
Availability varies depends on country and region.
